77broncodriver
- Joined
- Aug 25, 2017
- Messages
- 8
Hey Guys,
New to the forum here. Well Ive been reading for a few years but first time posting.
We are building a 30' x 40' red iron detached garage on our property, just signed the papers and getting the permits set up now.
While we are waiting for the building to show up I am going to start trenching and laying conduit to run the main power to the new garage.
We have a 200amp main panel but we can not easily access it without tearing up 10' of our driveway concrete which isn't an option. When the house was built the builder added a junction box about 10' from the main box and has 6 gauge aluminum cable (still needing to be confirmed) going to it from the main box which we are planning on connecting to.
The junction box is ~120' from where the sub panel is going to be located in the new garage. Is there any way that we will be able to feed 60amp with what we have? Is 50amps even possible at that distance or are we stuck with using a 40amp breaker in the main panel?
If we can not get enough power from this junction box location we have another junction boxed wired the same on the other side of the house that we can pull power from and add a second sub panel at the garage. This one probably has 80' of 6 gauge aluminum cable from the main panel to the junction box and then we would have to add another 90' from the junction box to the garage.
I plan on eventually getting an electrician out to help but for now I would like some advice on what options we have here in the mean time.
Thank you,
Evan
Thank you,
Evan
