Power to the garage.
gibble
Kept seeing this site when looking for information on google, so I figured I may as well ask here.
I have a 20x30 garage with no power currently, which I want to change
My house meter is "Type D4S". It has two wires coming out, the first to a single panel containing two 100amp, 250v fuses that then runs to my 20kW furnace. The second wire goes to a 100amp, Federal Pacific Stab-Lok panel.
I had a new Federal Pioneer 100amp Stab-Lok panel I had wanted to use in the garage.
However, after an electrician took a quick look, I can apparently only put in a 60amp breaker into my house panel to supply the garage.
The garage will contain an air-compressor, stove, welder, and basic tools. I'm not planning to put in electric heat, however, it would have been nice.
Will 60 amps be enough? Can I still use the 100 amp panel since it will be limited to 60 amps in the house? What size wire? We were going to use Teck 3 when we were thinking 100 amp service, but since it seems I can only do 60 amps, what wire should I use? Is there a way I can still do 100amp service to the garage?
Basically I'm trying to determine my options.
Thanks.
If it matters I'm located in Stonewall, MB.
Falcon67
Merkel, TX
60 ought to be plenty for what you're doing. You can put a 200A panel on the far end of that 60A run from the house, won't matter. The main in the shop panel will just be a local disconnect.
No note on distance, which could affect the size of the wire.
Norcal
Federal-Pioneer? You must be in Canada, is your house panel F-P? If not I would match it what ever make you do have.
To those in the USA, Federal-Pioneer is not the same as Federal Pacific Electric even though the Stab-Lok breakers interchange, F-P did not have the safety issues of FPE.
