racbikes
Hi every body i have a couple reciprocating saws that i am having issues with maybe somebody has had the same problems or has an idea about the tools to whats wrong with them.
The first one is a Makita reciprocating saw the problem with this one is when you pull the trigger the motor only works in certain potions or angles. it does not work if your trying to cut with the saw with the top facing up if you flip it upside down it works.what could be casing this?
the second one is a Dewalt reciprocating saw the problem with this one is the motor jams.If you shake the saw or sometimes bump it
it will start working again. i mean the motor jams by when pulling the trigger the motor runs but the blade does not move.i have already replaced the brushes on this one and the gear as it was badly worn but the saw still has the problem with the motor /blade jam. it jams when not even trying to cut so there is no fore or binding cuts.
any ideas to either one of these saws to what the problem may be or if anybody has had similar problems what was the fix? thank you in advance for any help available.
it will start working again. i mean the motor jams by when pulling the trigger the motor runs but the blade does not move.i have already replaced the brushes on this one and the gear as it was badly worn but the saw still has the problem with the motor /blade jam. it jams when not even trying to cut so there is no fore or binding cuts.any ideas to either one of these saws to what the problem may be or if anybody has had similar problems what was the fix? thank you in advance for any help available.
