Power trencher and roots
I am planing a garage, but the foundation will likely be within 10' of a large tree. I would like to do as much as possible myself, including digging the footing, with power of course !
Are the walk behind trenchers you can rent for most equipment stores powerful enough to cut through 2-3" tree roots, or should I just hire the job out ?
mothgrey
They generally won't go through one 3" that I have seen. But it's easy to raise the bar and use a saw to cut it out of the trench then keep going. It also depends if it's a dead root and how soft it is.
GarageEnvy
Fresno
The Ditch Witch I rented from United and Home Depot both had issues with tree roots. The Bobcat stand on unit (a lot like a Toro Dingo) I rented was diesel and had no problem with roots. It wasn't that much more and came with two scoops, an auger and the trencher.
jhelrey
MN
Oh, they will cut but don't force it... Keep it in N at that point and slowly lower the blade onto the root.
SGKent
Citrus Heights CA
depends - the big ditch witch we rented would have cut rocks as it had carbide cutters on it. Probably depends on soils where you are.
Jason Lister
Coarsegold, CA
Trenchers come in many sizes. How deep and how long of a trench are you needing? More specifics will help you with an accurate answer.
I do see that you mentioned a footing for the foundation... What equipment were you planning for that task?
Otherwise, everyone else has given good information.
Garage Envy: "Ditch Witch" is a brand name, much like Kleenex is to facial tissue. The, likely MT52 or 55, Bobcat you rented is in a class of machines labeled as mini skid steers or track loaders and are awesome machines that have a TON of utility available.
mm08822
A trench for a footing/foundation will need to be any where from 12" -36" wide depending upon your materials of construction and depth you need to reach for the frost line. A trencher is typically good up to 8" widths (4" more common) that I have seen. You only get one pass with a trencher as it uses the newly formed walls of the trench to help contain the spoils as the chain is drawing them out. You should be looking into a backhoe - either one you rent or for hire with operator.
PRH44
Indiana
A mini track hoe excavator with a 12" bucket can make short order of that work
ForceFed70
BC, Canada
x3
Just finished up with renting a walk-behind trencher for putting in underground irrigation.
The unit I rented only cut a 4" wide trench and didn't like roots at all.
steve308
If i'ts a big tree --- take it down now. Cutting the roots will probably kill it quickly and it's easier an cheaper to have them removed now than later
BFHgarage
Southwest Virginia
Be careful when you are building that close to a large tree, you can easily end up killing the tree if you eliminate too much of the root zone. Removing a tree with a building that close to it is not fun, or cheap.
Nighttrain
Dripping Springs, Tx
X4 on a mini excavator. I rented a bob cat excavator for about $270 a day to do some drain lines because the trencher was already rented out. Glad i did it made for much easier work and it was a blast.
