Power washer hose
Bmberzins
Hello, Thanks so much for all the great responses on the shop creeper stool. I have a pretty nice power washer, 3300psi, with about a 20 ft hose from the washer to the wand. Problem is if I try to extend the water line, from home to power washer, I lose power significantly and it stops working off and on. Curious if replacing the machine to wand hose with something longer might work. Any advice would be appreciated.
Ing3018
Michigan, USA
I experienced a similar problem that I traced back to the garden hose suppling water to my pressure washer pump. It had a flow restriction due to the repair couplings being too small.
Try a different garden hose if you want to have the pump further from your home. OR, get a longer pressure washer hose if you want to work further from your pump.
