power windows help
Chadwilliam1
Cincinnati
I have a 2003 Nissan frontier SE 4x4 Crew Cab.
About 3 days ago my power windows quit working. None of the switches work and the child lock is not on. All 4 windows are up and I checked all the fuses. I can not find where the power window relay. my Haynes manual says it is just above the interior fuse box behind the instrument panel. I looked all over and I don’t see it. I even took the instrument cluster out and I don’t see it. I took the drivers door switch out and checked to see if I am getting power to the switch. The switch has the power door locks on it and the window controls. I checked for power and in two spots I got 4 volts but the door lock switch does work. I tried the power mirror plug and was able to find a 12 v wire. which is also on the driver side armrest.
If I remember correctly it quit working while I was sitting in my truck waiting for a parking spot at work. So my truck was off and I turned the key on to roll the windows down and they wouldn’t move. Which makes me think the relay stuck.
water-works
Does your setup look like this and if so, did you check the left kick panel for the power relay?
C
Chadwilliam1
Cincinnati
That looks right. I didn’t look that low or I must have missed it. Thanks, problem is i have a 2 year old and a new born so I have very little time to work on it.
