rieferman
Hello,
I installed a powered roof vent per the manufacturer's instructions in the roof of my barn. Ceiling in the space is finished with sheetrock in a vaulted fashion up until the collar ties where the ceiling is flat (tray) creating a mini-attic cavity near the peak. Baffles installed under the insulation allow air to travel from the vented soffits on both eaves to that cavity. The roof vent is then installed centrally close to the ridge to draw the hot or moist air from that cavity (the roof vent has a humidistat as well as thermostat).
The good news is that it's working. When it's hot or humid, the fan kicks on, runs for awhile and then kicks off. Repeat as conditions require.
The bad news is that is sounds like a helicopter is flying far overhead. It's not so annoying as to drive me absolutely crazy, but it's noticeable for sure. I can hear this through the insulation and the glued/screwed sheetrock. The vent is at 12 feet above where I'm listening from.
My hypothesis is as follows: The barn roof rafters are 24" apart with 1/2" plywood over ancient lathe strips. The 14" fan cut out is centered in the 24" space, and I think it's basically turning the plywood/lathe into a drum. That drumming is what I hear (and sounds like a helicopter).
My proposed solution: From the underside (through the hatch I thankfully had the sense to leave myself) stiffen the area supporting the fan so that the vibrations is absorbed. I was thinking something like a 3/4" layer of rigid foam against the roof deck (glued) followed by a 3/4" layer of plywood (also glued). Block those both in place with 2x4 framing between the existing rafters.
What do you all think?
Thanks in advance!
Thanks in advance!
