I'm on the tail end of a huge shop power upgrade and need some assistance on wiring my air compressor. The compressor is a 80 gallon, single phase 230v, 7.5HP North Star unit from Northern Tool. It comes with a prewired Eaton motor starter, I just need to connect it to my electrical service.
When my electrician completely reran the shop service, he ran me a direct line from the panel breaker to the starter box. He was hesitant to hook the compressor up as he'd never connected a motor starter before and wasn't too sure where to connect the power based on the directions.
From my searching, I haven't seen anyone with a setup identical to mine. I have four wires going to the box (two hots, a neutral, and a ground). It looks like I should be installing one hot wire to L1 and one hot wire to L2. I'm not sure what I should be doing with the neutral wire and the bare copper ground wire.
In similar photos I've seen on here, the neutral wire is wired into a ground bus similar to what exists in the bottom left hand side of my starter enclosure, however, most of those setups didn't have the "L3" like mine shows.
Directions:
View media item 59406
Motor Starter:
View media item 59409
Directions:
Motor Starter:
