Pre-1940s Outboard Motors
Maui
Upstate NY
I just picked up 6 antique outboard motors today. Here are a couple of photos. The pic that includes 4 of them has a 1940s era WaterWitch on the left, a 1939 or 1940 Johnson 5 hp next to it, then a 1925 or 1926 A-25 Johnson, and then a 1939 Evinrude Elto. Pictured by itself is a Champion motor, and then another (earlier) Evinrude Elto. They all have good compression, and I'm going to see if any of them will run. Any suggestions on what websites to visit for good information on getting these motors back up in running condition? I can tell you that 4 out of the 6 have a significant amount of rust inside the tanks, so that has to be cleaned out before anything else gets done. What is the best way go about doing that in your opinions?
I was reading on a Dietz lantern rehab page to put a bit of kerosene in the tank, and a foot of sash chain, and swirl for a while. I suspect that could be scaled up to a motor tank.
zendriver
Indiana
Got spark? :dunno:
Tank cleaning, Unless you got a lot of time to kill, I'd suggest rigging an separate small fuel tank, until they are verified to run.
I fiddled with an old Neptune that was at fishing cabin we were at. Definitely got a good workout on my pulls start arm and a chance to practice up on swear words. :lol:
Looks like a pretty fun find for you. :thumbup:
  • Like
Reactions: RTM
Here is the web page
MushCreek
Upstate South Carolina
The AOMCI is the authority on this stuff. It costs to become a member, but I think you can ask questions on their website. I used to be a member, as I have about a dozen old motors, going back to 1922. Most old motors aren't worth as much as people think they are worth.
Ole Slewfoot
Freedom, CA
Remove the tank, half fill with soapy water and a handful of nuts/chain, shake it around a bit, drain and rinse.
Run some solvent through if at all oily.
Evaporust.
Leak check.
Outboards you ann pick up with one hand are the best! I dig the tank on the leftmost unit, not familiar with that one.
Maui
Upstate NY
Evaporust.
Leak check.
The motor on the left hand side is a WaterWitch. It does stand out from the others in how it was designed.
I did check out the AOMCI website. I am still deciding whether or not to join up. I probably will.
I’ll try to find that book on Amazon Ronnie. Thanks!
