This is my first post as a year long + lurker/researcher. I'm at the point where I've saved and done enough research to start a build of my own pole barn, but I have a few questions I haven't been able to readily find answers to. I'm limited to a 30X40 based on city limits (max size has to be less than the footprint of the house). Hopefully someone can give some suggestions or advice on where to look.
First roadblock I'm coming to is locating the septic system to build far enough away from it. Couple of notes on what I've found so far with city records:
-Septic system built in 1969
-Entails 2 tanks (one of which has an access port) and 2 dry wells
-Location is very poorly defined other than the distance to the access port (closest to home)
-Local septic companies don't 'locate' any features
Does anyone have any good suggestions on how to locate the dry wells besides digging holes in my yard where I think they might be? There are no visible changes in how the grass grows, snow melting, or anything beyond the concrete cap of the 1st tank. I need to know how far back this goes so I can avoid building too close and get the permit approved showing that.
Second roadblock is prepping the land once permits are pulled. Mostly just looking for validation on my thought process for order of operations and some general questions in between:
1. Stake out site and get city inspection
2. Remove all grass from the space
3. Start the fill dirt/leveling process - how high should the dirt at the high end of the grade be above the existing grass? Is fill dirt alone acceptable for this?
4. Dig post holes, get inspection, and move on to the framing process from there
5. Concrete after framing? or before? I may bring in some local Amish for the framing and site prep. From what I have seen they usually build without any concrete in place then have the slab poured by a separate contractor. Any reason to go one way or another?
Thanks in advance for any input.
