Photos......but if you have a block foundation, look at the stud location in relationship to the blocks. The blocks are 16" long, and the studs are 16" on center. It makes it an easy way to locate them.
If you have a solid poured foundation, score a line at the center of the stud into the concrete on the vertical stem wall, then you will always have a reference point. Or if you can't do neither, make a folder for your desktop on the computer, then add notes to the pics before you save them to the folder. You may have to do it in paint before you save them. Next.....have a tape measure up from a corner to the studs, and snap a pic. First a close-up where the first stud is located, then step back a short, and snap another pic showing stud centers.
Lastly, make a physical folder that you can keep in your desk or somewhere in the house, with all of the pics, dimensions showing, and so on. Then you can always reference back to it if the need arises. This is probably the best way as if your computer ever crashes, or if you buy a new computer, you may accidently forget to transfer the files over. Don't ask how I know that.
