lonesouth
Anyone plumbed the compressor intake into their AC ducts to provide dryer air to the compressor as a means to get dryer compressed air?
i would think that would cause even more condensation....
the cooler air intake vs the heat generated by the air being compressed...
i'm probably wrong...
i usually am, just ask my wife
How could lower humidity air entering it hurt?
My take on using the AC air....the positive effect (lower humidity) using a cooled air supply is lost as the compressors process of compressing the air generates a lot of heat...try putting a finger on the supply from the compressor to the tank, you'll understand. The generation of moisture will continue and may even be more so as you introduce cooler air to heating process. If moisture is your concern...your level of concern will probably dictate how far your willing to go in minimizing it...do a search for "compressor air exchangers" You Tube also have DIY videos on them. While exchangers are on the outlet side of the compressor and before the tank...to effect the supply air before it enters the 'breather' you'd have to craft a chamber that would actually heat the supply air...minimizing the temperature difference between the 'supply air and the compressed heated air'.. My .02
