Precision Matthews PM-932M-PDF Milling Machine
Atlascycle
Fremont, Ne
Fremont, NE
Price
$1,500
MACHINE IS SOLD
9" x 32" Milling machine for sale, 3 axis DRO Display, Scale is missing from the "Z" axis, has digital Quill Readout, power feed on the X axis, Power Feed to raise and lower the head. Collets included, 1/8", 3/16", 1/4", 5/16", 3/8", 7/16", 1/2", 9/16", (2) 5/8", 11/16", & 3/4" also 1/2" Drill Chuck on a R-8 Arbor. VISE IS NOT INCLUDED, 6" Vise is too big for this machine, a 4" or 5" will better fit this machine
Machine is Located in Fremont, NE $1,500 obo
http://www.precisionmatthews.com/shop/pm-932m/
Main Specifications of PM-932M:
Table Size: 9″x31.5″
Max. Table Load Capacity: 300 lbs
Table T-Slot Size and Number: 14mm / 9/16″, 3 Slots
Table Travel, X Axis: 22-3/8″ Hand Only, 19.5″ w/ Power Feed
Table Surface Height from floor, 34-3/4″ (With base flat on floor)
Base Dimension at floor approx. 18-5/8″W x 27″D
Normal Working Max Height: (top of column travel motor) 76-1/2″ (with optional stand)
Height with head all the way up: (top of main motor) 81-1/2″(with optional stand)
Stand (Base) height, to machine mounting surface: 24″
Cross Travel, Y Axis: 8″
Head Vertical Travel: 17″
Max. Distance Spindle to Table: 18″
Quill (Spindle) Travel: 5″
Lead Screw Type: Inch Pitch Acme Threads
Spindle Taper: R-8, with 7/16-20 drawbar thread (U.S.
Standard)
Quill Diameter: approx. 3″
Head Tilt Front to Back: N/A
Head Swivel: Side To Side, 90 Degrees
Ram Swivel: N/A
Power: 220 Volt, Single Phase, 9 Amps
Motor Horsepower: 1.5 H.P. (Some other similar machines will say
that they are 2HP, but its the SAME exact motor as this one, just rounded
up to 2hp and marked that way, we prefer to be honest and mark it as
what it really is, which is 1.5HP, which is more than enough power for
this machine either way)
Casting Type: Fine Grain Cast Iron
Approximate Weight: 1100lbs with Stand, 850 Without Stand
