Prep advice, very old garage...
joony
So I've been looking to epoxy the garage for some time now and finally really looked into it. The house was built in the 50s, so that makes it almost a 60 year old garage.
After sweeping for dirt, I realized that it was a lot worse than it really was. Here are some issues:
1. Some of the concrete is chipping away in thin flakes
2. There is a 'rocky' concrete under the chipping part (is that normal?)
3. None of the concrete is absorbing water
From what I've been reading, shot blasting might be a good option, but pricey? It's about a 11x22' garage.
Do I need to level off the concrete? I'm not sure if the Rustoleum concrete patch and repair is for giant patches like mine...
nissan_crawler
Wichita, KS
Mine was built in 1950. When I bought the house, the garage floor was covered with an inch of grease, oil, and dirt. It's a 20x24 garage, I spent 13 hours pressure washing it, 6 gallons of purple power, 2 boxes of TSP, and the acid. I put the rustoleum epoxy on it, and it's lasted through 5 years of welding/torching/grinding/plasma cuting/gas spills/oil spills/you name it. It still looks fine.
J
joony
That white stuff is just road salt that I haven't hosed out yet. I'm pretty sure it goes away, I hope...
This is near Chicago.
thegarageguy
What you have there is heavy detirioration. A thin film epoxy system would not be recommended. If this was a sales call that I went to, I would not offer an epoxy system but rather a resurfacer. A resurfacer would be a resinous cement or a portland-urethane mix. Then epoxy over that for a decorative look.
That would be my recommendation.
SC-Eric
Spartanburg, SC
While we do offer resurfacing products, it doesn't look like you need it fromt he pics to me. The cost would be a bit much as well.
Our BondTite 1101 primer and LiquaTile 1184 is routinely used to fix areas as bad as I see there. You will probably need to do one extra coat to level the concrete.
thegarageguy
The time and effort to skim coat patch all that detirioration would be much. Maybe if you had a mason on your family or someone in your family married a potuguese. Then that extra coat....would bring the price back up. You'd still be very thin, even with a heavy broadcast. Tops, 3/16 inch thick??
A resurfacer goes down 1/4 inch to 1/2 inch thick and you can literally take a hammer to it and it will not shatter or crumble. Done in two days!
But hey, different strokes for different folks. There are definately many ways to skin a cat. Professionally done ofcourse. :)
