Hi All,
First-time poster here seeking advice on additional step of prepping for optimal polycuramine coating results. I've learned a ton from you all and I believe this is the only place that can help me with a specific question regarding moisture barrier.
Current status:
I learnt from this forum that mositure barrier is basically a modified sodium silicate densifier, which will form a gel in cracks, pores and capillaries. Yet in my understanding, part of the mechanism of polycuramine coatings rely on penetration of the concrete's porous surface and forms a strong molecular bond. Am I creating a problem here?
Questions:
Any advice from those who've tackled similar projects would be greatly appreciated. Thanks!
Current status:
- Floor has been diamond ground; Cracks filled and re-ground. Unsure about existing moisture barrier and not very optimistic
- Apply moisture barrier, then polycuramine coating following both product's insturction. Both from Rust-oleum
Questions:
- Would prep the floor again after the moisture barrier cures help? Maybe pressure washing + dehumidifer?
- Or am I overthinking this and should just follow the moisture barrier instructions?
