Last year I coated our garage floor with epoxy, and have some coating failures. I cut some corners in the prep work. I have since stripped the old coating off, and ground the entire floor.
I do have a question about the troweled control/expansion joints.
How can I effectively Clean, and Prep them for the new epoxy coating?
So far I have tried grinding them with a 4" diamond grinder - works ok, but really cuts into the edges of the joints, and leaves coating on the bottom of channel. Used a wire brush wheel attachment, - that removes the coating very well, but appears to 'polish' the concrete - looks like all the concrete pores are full. Finally been mostly using a hammer and chisel to Slowly remove old coating piece by piece. These methods remove the previous epoxy coating, BUT not the Source of the failure.
My current thinking is since I have ground the Flat floor surface, I must use an acid etch to etch the curved troweled surface.
Any thoughts or ideas are Very Welcome. Thank You in Advance.
