Anybody feel like making suggestions or changes to my plan of attack?
FYI,
I plan on applying the epoxy in my garage in two separate stages, one side at a time. Unfortunately, I have no alternative location to temporarily store my garage contents.
*The expansion joint in the middle makes separating the two sides simple.
Stage 1: RIGHT SIDE OF PIC
Stage 2: LEFT SIDE OF PIC
Here we go...
Preparation:
- Move all contents to RIGHT side of garage floor
- Begin prep on LEFT side
[*]Mask exposed areas of wall about 4 feet up (is that enough?)
[*]Sweep up dirt, and scrape off any paint or other material stuck on the floor
[*]Remove oil stains with degreaser, brush and a lot of elbow grease
[*]Etch the concrete with 1 part muriatic acid and 4 to 5 parts water
[*]Spot etch with a stronger solution, if necessary
[*]Hose down floor at least 3 times using a squeegee between each rinse
[*]Let dry for as many days required to pass the "plastic sheet taped to the floor test"
2nd DAY OF ACTUAL WORK
- Move all contents to LEFT side of the garage floor
- Begin prep on RIGHT side
- Epoxy RIGHT side of garage floor
3rd DAY OF ACTUAL WORK (when epoxy on right side is foot-traffic ready)
- Broom and rinse LEFT side of garage floor (do I need to etch the floor surface again here?)
- Epoxy LEFT side of garage floor
SOME DAYS LATER (when epoxy on right side is foot-traffic ready)
- Return all contents to original respective locations
- Park the cars!
- Post pics on GarageJournal
EDIT: Sorry if these seems redundant guys...I just don't want to have to "think of what to do next" after actually beginning the project.
