palsor1
Hey guys,
I need some advice on getting my garage floor flat (not level).
We moved into our house years ago and I'm just now getting to the garage. I purchased enough Racedeck Tuffshield to cover the floor. After some investigation prior to installation, I discovered the floor of the garage is not terribly flat. It's not horrible, but if I set my long straight edge on the floor in various places, I can see high and low spots where the total delta from high-to-low is somewhere between 1/4" and 3/8" over maybe 5ft. After a quick conversation with Racedeck, it sounds like they recommend trying to get it flatter than that.
I have two concerns. First, there are quite a few oil and tire stains on the floor, some from me, some from the previous owners. They make me worried about getting any sort of concrete filler or compound to stick. Second, the garage floor is sloped. I understand why (building code), but I believe that means that using self-leveling compound is not an option.
So, I think that means I could do one of the following:
Thanks for any advice.
Andy
- Live with it and hope the Racedeck does ok. I'm not sure I trust this. Any thoughts?
- Try and grind the high spots down. I'd probably try and rent the EDCO 10" grinder that's available at Home Depot. My concern with that is that I will ultimately just make a mess of things. I'm a fairly capable home improvement guy, but that just seems difficult to get just right. Anyone done this?
- Do some concrete prep and try to fill the low spots with something other than self-leveler. This seems the most likely to yield success to me. If go this way, the steps probably look like this:
- **** up the worst of the oil stains with something like this: https://www.homedepot.com/p/Goof-Off-32-oz-Concrete-Cleaner-Degreaser-FG820/300723090
- Rent a Diamabrush from Home Depot and scrape away the rest of the dirt and oil stains.
- Use some kind of filler to fill the low spots. I'll have to do my best to get everything flat by screeding with a very straight board or something.
Andy
