Press and pull sleeve kit
phikshin
I'm looking into buying a press and pull sleeve kit. I've got a few bushings to do in a knuckle / arm that I can't see coming out of the car nicely and even then doesn't seem like it will be a very easy to somehow center it and Mount it on a press.
Has anyone bought or used one of these? Are the knockoff versions of these any good?
This is the kit I'm looking at:http://www.amazon.com/gp/aw/d/B002O...110_SY165_QL70&keywords=Mueller+kueps+600+400
LXCam
You might check out Miller tool on eBay for your cars specific tool kit. I've bought several for under a hundred. But that does look like a decent universal kit.
Anarius
What is the specific vehicle? Maybe I can help....
I generally use a ball joint press or a shop press to push bushings.
MadTinkerer
I have that mueller Kueps and like it. It can be found from other sites for a lot less then that though. I think I bought mine from thetoolwarehouse.net for under $400. It took a few weeks to get as they had to special order it.
