Press Brake - Bend Press overview
KwikFab
Central Valley, CA
Hello group.
I don't normally do this for products, since you can often find information and videos on just about everything out there. But I figured some of you could benefit from what I have to share.
I want to add that I'm just a regular dude working out of his garage; I am in no way affiliated with Trick Tools and they did not ask me to post a video or even share my experience with them or the product purchased.
Being a disabled veteran puts me at a disadvantage having to be mindful of how spending is done with tools which usually means I'm doing as much research as I can before committing. In this particular case, there weren't any threads or even videos on this press brake so I thought I would help others in my situation by sharing my own experience.
To preface: since working for myself out of my garage, I found myself from time to time being asked to provide bent parts. Before I ever got into bending metal with the help of other tools, my only real means for bending was with relief cuts done via a mini cut off tool or angle grinder.
It wasn't until I got myself a CNC table that I strictly switched my operation to relief cuts all done via CNC as it was much easier and far more precise.
Here are some examples -
As I began to offer more work, the demand grew for things such as skid plates, custom mounts, and more. That's when I invested in the Swag Off Road HD finger kit and Harbor Freight's 20 ton press.
It was great as now I had the ability to bend thick steel without the use of relief cuts which mean I was able to add more to the menu.
However, it fell short as I still had a large demand for smaller bent parts done on thinner material.
Even if it was something I was making for myself, I was left extremely disappointed with the large bend radius it would create. This is an angle grinder holder I had made for my welding table out of 16 gauge -
I followed the advice given which was to stack angle iron on top of one another. I went as far as to making my own sort of bottom die by welding up smaller angle offset on rectangular tubing; it barely made a difference.
So the Swag kit got boxed up, the press sold off, and back to relief cuts.
The downfall with having to do relief cuts is that, you would need to perform a rather large cut on really thick metals if you want to keep it from warping. This also meant that the part itself is weaker which means it needs to be welded up.
In turn, this meant more work.
K
KwikFab
Central Valley, CA
With all that out of the way, that's where the Bend Press BP1020 came into play.
I am not sure how I ran across it, but I remember Googling different press brake styles in an attempt to find something that uses better tooling.
Not sure if it was a sign or not, but when I found the BP1020 on Trick Tool's website, it happened to be on sale for $50 off for the Deluxe kit.
Here's when it finally arrived -
What pushed me to commit was the need to create a number of mounts needed by a shop local to me. I normally make them shock mounts, motor mounts, and other odds and ends for custom fab work but they too wanted to cut down on the amount of welding done on their end.
Excited to get it all together, I threw on an old bottle jack I had laying around and put it up on my extra end table.
Since then, I'd made a few changes which included buying an air over hydraulic jack on Amazon, as well as a foot pedal and extra air hoses to run everything.
I also made a small mount for my foot pedal, something I never got around to doing with the Swag kit.
Anyway, you can read more about its capability on their website which I won't bore anyone with although I'm happy to share just some of the bends this thing offers.
This is a 16 gauge part, bent with a relief cut -
And a 16 gauge part bent on the Bend Press -
You can clearly see the difference in the bend radius.
What I found most impressive was how accurate it is in providing a crisp bend with such a tiny flange. Here's a sample of a part I made for a customer -
I found 3/16" to be a treat as well -
So I hope anyone looking at this press brake finds the information here helpful!
But, if you hate reading and are more of a video person, here's a poorly shot video I recorded earlier today -
I am not a youtuber, I don't have many followers, so if you liked or subscribed that'd be awesome.
Again, just a regular dude working out of his garage!
Semper Fi!
Jgaz
Excellent review!
Thank you for putting it together.
Anything of the sort that you want to share here would be appreciated (at least by me)
K
KwikFab
Central Valley, CA
Excellent review!
Thanks!
I enjoy a good review myself but like I mentioned, I couldn't find any info on these much less videos other than those done by Trick Tools themselves.
I believe the price point made it really off putting compared to say, the Swag kit I've had experience with.
For anyone that's done autocross, the Swag feels more like an SN95 vs an NA Miata. Sure, the Mustang might offer a bit more everywhere else, but the Miata is really purpose-built and excels at the track when comparing the two.
The Bend Press just feels like a real press brake, albeit a small one.
FigN⋅m
Appreciate the insight!
Looks like a well sorted shop too - with as much cool stuff in the background as in the foreground (Cowabunga!)
Did you by any chance ever get to try SWAG's Flat Top V die kit? Even though they are quite literally down the street,
I'm still debating going their route for my press. Trick Tools has always brought the heat - and this seems no different.
Great food for thought and good motivation to get cracking on my own "TEQ" projects...:cool:
K
KwikFab
Central Valley, CA
Ha thanks!
Nick Palma signed it himself!
Super chill dude and quite the martial artist.
Joked with him about throwing hands being a boxer myself but who am I kidding, the guy is really talented.
To answer your question though, no I have not. I wrote off the Swag kit after I decided I no longer wanted to invest in a low end kit where money can be better spent elsewhere. That's what led me to go back to relief cuts and welding.
At the price point Swag demands, I'd expect a solid V block die to be used, or at least making the flat top kit standard. Really good at nickel and diming you...
With that said, Swag's kit is still a decent one. I know I made many mentions of their kit above (as well as in my video), I wanted to drive the point being that the Bend Press picks up where the Swag kit begins losing steam.
If you favor making precise bends on thinner materials (with better tooling), then the Bend Press is the way to go. If you favor bending larger pieces on thicker metals and your plans allow for a larger bend radius, then the Swat kit is perfect for you.
By the way, nice catch on the TEQ ;)
I haven't cut any related-parts in quite some time now.
FigN⋅m
Ha! That's awesome! Such a good flick - I even went as Casey Jones for Halloween after it came out.
I hear you on the SWAG kit...I really want it to perform like a higher-end unit that matches the $$.
I've also considered just fabbing up my own version at least for some basic stuff.
Those TT bends look nice! Definitely looks worth the investment. Do you miss having a finger brake?
I'm not sure how often I'd need it, but it does seem like a handy option just in case...
K
KwikFab
Central Valley, CA
Grew up with the movies, had them on VHS even!
I will be fabbing up my own though. In fact, I have a short 4" bottom die being shipped to me that I'll use as a mock up which reminds me...I need to find a 4" punch that's centered above the tang as well.
I intend to fab up my own brake, but even if I don't go that route for some reason, I will be fabbing up my own brake attachment.
The goal is to use American tooling as it's cheaper and readily available here in the US. I was originally looking at one offered on Ebay (look up Cyclops Designs) and as nicely made as it is, it uses Euro tooling which is significantly more expensive to find as well as being uncommon.
Still though, I toy with both ideas.
Which then leads me to ask - with the many press brake attachments available out there, why isn't there one that's made to accept American tooling? You've got a ton of DIY videos on youtube, Swag, Eastwood, Chinese variants on Ebay, and tons more all being closely related to one another with the exception of Swag's finger kit.
I thought it'd be useful in having owned the finger kit, but it wasn't for me. Not that there was anything wrong with it, but I really think people should ask themselves "what are you really wanting to make?".
In just the short month I've owned my Bend Press, I've used it a ton more than the Swag kit I owned for over a year; that says something.
Ever since I moved onto something that provides precise bends, I don't think I could ever go back.
FigN⋅m
You raise a good point regarding intent.
Most of my fabrication is based around tube bending & notching,
but I always need to make some little plate/mount/thing and rarely
do any box work, so "need vs. want" and all that...
Thanks again for sharing your experience, lots to consider!
nutjob
NE, PA
This is a very nice stand along press brake, I like that it comers with a 4 way v-die. But it is 10" wide and costs over $900 shipped.
I have this press brake:
https://www.ebay.com/itm/3156181092...q8L4H/8luKYPfSxSfdrJZtmVk=|tkp:Bk9SR87oxcilZA
12" wide with a single v die that is 1 1/2" wide. You can remove the die and bend 3/8" and thicker against the round bars. Trick tools does sell a 2" wide 10" long 4 way v die for $219 plus shipping which is a very good price which could be adapted to this brake.
But neither one has a back guage or fence or work support or finger options but these could be fabbed and added.
I found these pics a while ago but can't find anyone selling them:
Even these small press brake are super helpful in the shop, really adds that professional looking bend vs a block of wood a BFH!
Kevin
K
KwikFab
Central Valley, CA
https://www.ebay.com/itm/315618109249?itmmeta=01J4P8HEH1X1KDNGSB49PJ4KYW&hash=item497c4e2741:g:XvEAAOSwpz1mqfmT&itmprp=enc:AQAJAAABAG5IG50eT4bdiS1yhG84K+PlGFSRlid5bsYBaqlc9if9ZLLDNi3jLYai3ClUx5KzjVtrpIUEuN4S+i/UxHfiGWHMr912/NEvTi0hPirr09zHdVJs+7Fa9M61mJlny/djN4LRKc5Pnl2LOhbcE7rbKWJgz7krQs6lO3oskDzRxKbjso7n1aPQo7fjkvb6HFSgO1Mlytyr3EYAz3RdMhvLFiRERm30WDiqfXXZGwjax9L7k1IqK9lFyrH/Pb5LbdfmrUdY33jmV1rghPkNIvxYq50wkRNzTT2q5R4hORbxdxh3rUgby5OQwerGetC29zq8L4H/8luKYPfSxSfdrJZtmVk=|tkp:Bk9SR87oxcilZA
Kevin
I mention these types of attachments in post 10.
Basic bending tool, and will get the job done for a hobbyist (what I still call myself).
But not a tool I would suggest for doing the type of work I mentioned above.
