drummerdimitri
I bought a used industrial polishing machine and currently in the process of restoring it to as close as new as possible.
I have take the arm off that houses two bearings on each end and a shaft that goes all the way through.
My new hydraulic press should be arriving soon and I would like to press the shaft out of the housing to clean and regrease it.
Since I have no experience with such a job, I wanted to ask for guidance so that I don't end up breaking the part as it cannot be replaced.
Is there a direction to press it out or can I press it out from either end?
I've removed anything that was previously attached to the arm and any nut/retaining ring on the threaded portion of the shaft and it now rotates freely but hammering the shaft only moves it a few millimeters each way but wont remove it completely.
