2ndGearRubber
Replaced a rear caliper on a 2021? GM truck. Traditional bleeding with two people lead to zero fluid flow, service info says to pressure bleed below 30psi. So now I'm in the market for pressure bleeding tools.
It appears that I can either just pump up the empty container and push the fluid currently in the master cylinder through (to bleed a single wheel), or fill some volume of fluid in the container with the intent to flush the system? Ideally one would fill with fresh fluid in the master cylinder if doing more than a basic single wheel bleed.
Anything I need to look out for with these units? If I can just pump up the empty container, or use shop air, to do a one man bleed on a caliper replacement I think that would be a big plus for me. I'm not trying to use several quarts of brake fluid to flush the entire master and the whole line just to bleed a caliper.
Motive and Mityvac look like the major brands?
