HomeTheaterMan
- Joined
- Apr 3, 2016
- Messages
- 493
I have a horizontal Craftsman 33 gallon air compressor that is about 10 years old. I'm sure I'm not using the correct terminology for these parts, but hopefully I can explain it well enough. Anyway, the pressure gauge on this thing broke and now has the insides folded up and is stuck on saying there is 40psi in the tank regardless of how much air is actually in there. This gauge screws into the aluminum block that the regulator is screwed into. So, I bought a Milton gauge with a 1/4" NPT fitting on it to replace this. I thought all air fittings were 1/4" or 3/8" and knew it wouldn't be the bigger of the two. Anyway, I pull this one off and go to install the Milton and to my surprise it doesn't fit. The fitting on the gauge that came on the Craftsman compressor is a lot smaller than on the Milton. I didn't have calipers handy so I'm not sure the exact size of it, but it wasn't even a close fit. Is there a 1/8th NPT fitting? I tried doing some searching online before I joined this forum and I can't find any gauges with a smaller fitting than 1/4". I'm also having trouble finding out what I have here or what I need. Is there an adapter fitting that will allow me to use the Milton? Anyone run into this before and know what size this thing is?
