Pressure regulator
wantacoe
Sycamore, il
My regulator says it only regulates 10-125 psi. Does that mean if there is 300 psi going into it the most it will ever put out is 125?
Jack Ryan
Adelaide, South Australia
The maximum inlet pressure is 300 psi so the regulator is not meant for a cylinder. It is meant for a second stage on a gas distribution system. It should say what gas it is used for.
The 10 - 125 psi range is the design operating range. It can most likely be set (a bit) above 125 psi and it can certainly be set below 10 psi, but it is not designed to work at those pressures - the actual pressure may be neither accurate nor stable.
Jack
PCustoms
VT
Jack
That seems like a lot of pressure for a second stage gas regulator.
I assumed it was for water?
W
wantacoe
Sycamore, il
Jack
Does that mean I can not use it for air?
Jack Ryan
"The first stage is non-adjustable and reduces the inlet pressure to an intermediate setting (typically 250-350 psig). The second stage is adjustable and reduces the intermediate pressure to the final delivery pressure. "
That's from one of Matheson's catalogues.
I don't know what fluid the regulator was designed for, or it's intended application - so I am just guessing.
Jack
PCustoms
VT
Jack
How did you identify this was a matheson?
jack stand
Lakes Region Maine
I will look at it tomorrow to see if it says on it.
Are you talking about an air compressor regulator, or for a compressed gas cylinder?
Once you mentioned Matheson (an air gas supplier) this conversation got complicated.
Every regulator for a "bottle" that I've ever seen has the appropriate female fitting attached for a gas bottle.
Air compressor regulators usually have a 1/2" female threaded in and out ports.
A better picture of your reg will be helpful.
PCustoms
VT
@wantacoe is the OP and didn't mention matheson as far as I can tell
@Jack Ryan brought that complication to the table, based on some catalog he was looking at. I'm still not clear how it ties to this thread
Jack Ryan
You questioned 300psi as an intermediate pressure for dual stage.
I used that catalogue to inform you that that was a typical intermediate pressure.
You then misunderstood the mention of the catalogue.
I clarified in the following post.
You still missed it.
Jack
W
wantacoe
Sycamore, il
More pics of regulator. No other markings on it.
BobnCO
That was a wild ride.., info correct about a different situations. We had welders giving welding gas info, plumbers giving water pressure regulator info.. : ) I figured compressed air.. but I had my new “compressed air” regulator in my hand last night! (Anchor Bias)
