PLOWJEEP
Three years ago, I had to replace the expansion tank on my heating system. While he had it shut down, I also had him replace the pressure relief valve and air separator just for good measure. Now my pressure relief valve is leaking again. Could it be that my expansion tank has failed after only three years? My system is an older install, it is a primary, secondary loop system with a four gallon expansion tank installed beneath an inch and a quarter air separator. The primary loop has two zones (180 degree). The secondary loop has two floor heat zones controlled by an injection pump.
Any help would be appreciated.
Thanks,
Brian
Thanks,
Brian
