Ramper
My used compressor has a pressure switch that cuts out at 100 PSI. I am looking for a little higher PSI. It is a 5 HP 220 and lots of the switches I can find are rated to only 3 HP. Any suggestions?
It is factory set and not adjustable. there is a security torx on the screw head.
Before you go and jack up the pressure switch make sure your tank is rated for more than 100 PSI.
