Pressure Washer gunked up again. Prevention?
HoosierBuddy
Southern Indiana
So, my youngest volunteered to pressure wash our deck as a Fathers' Day gift for me. Yea!
I got home last night and he'd made zero progress because our pressure washer wouldn't work. Boo!
Normally after you hook up the hose and turn it on, you can get water flow through the wand even without the engine running on the pressure washer. This time, Nada.
I took it loose from the hose and then took apart the water fittings on the inlet and outlet side of the pump. The outlet side had a bit of crud in it. The inlet side (brass fittings) was almost 100% blocked with this white chalky almost like concrete ****. I drilled it out pretty easily, rinsed out the brass fittings, reassembled and the pressure washer was back to 100%.
What did I do wrong here? I don't store it with a hose connected to the inlet side, so I'm not sure how it stayed wet and got so corroded. Does anyone use any sort of corrosion preventer in their pressure washer between uses. Ours only gets used a couple of times a year.
Thanks guys!
Hooked
League City, Texas
Was it actually corrosion? Many times I get insect nests built in openings like this and it's pretty hard stuff but doesn't require a drill.
Bucko
When you say you don't leave the hose connected are you talking about the garden hose or the pressure hose. If the pressure hose stays connected you will get galvanic corrosion which is what the white chalky residue is a byproduct of. I disconnect the pressure hose when done and wind it up with one end on the ground so most of the water drains out.
H
HoosierBuddy
Southern Indiana
I guess I can give that a shot. The way mine is set up, the pressure hose outlet is lower than the garden hose inlet. Once I have the garden hose disconnected, you are looking into a blank hole (with a screen over it). Just behind that screen, the hole was completely clogged. Seems like any water would drain out....but you are right. The corrosion would argue otherwise. I'll try storing it with the pressure hose disconnected.
WhoWhatNow
Collegeville, PA
I’m actually having a similar problem. I get a very sticky white substance on the filter of anything I hook up to my garden hose. I have determined it is coming from my hose. I am guessing is is some type of biomaterial that is growing in the hose or breakdown products of the hose itself. My hoses are all the older Craftsman black rubber hoses. I guess it is time for new hoses.
Take your hose and aim it at the driveway and see if you get a similar white substance coming out with the water.
Bucko
When I lived in a much colder climate than now I made the mistake of putting mine in the shed with the hose connected because I was planning to use in again in a few days. That did not happen but instead the trapped water froze and cracked the pot metal stub out piece that the pressure hose connected to. Now I always pull it apart even when I know it won't freeze here.
NUTTSGT
Northern Central Ohio
I've only had mine about 5 years and it lives in the shed, even during Winter. I usually run some RV anti-freeze in it before I put it away. Never had a problem till this year. Trigger on the spray gun crapped out and the turbo nozzle rusted in place I think.
I would think what you ae seeing is impurities in your water. City water or well ? Even city water can be harder than what a person might think.
nbpt100
Massachusetts
I had a similar issue on my 10 or 12 yr old Pressure washer. I was only worried about freezing as you never get all of the water out. I stored it in a basement that would never get cold enough. However it started leaking and when I opened it up it was all of that white aluminum corrosion residue. I guess I got my money out of it. Not worth rebuilding as you can never get all of that stuff out and it will just come back. A new pump was about $110 and easy to replace. I will now always use some kind of winterizer- anti corrosion chemical. It is more than just an anti freeze. Cheers.
Old Man Roger
Palm Coast Florida
I swear it was never a problem for decades, now it’s a constant problem. I know they now use a different kind of chlorine to sanitize the city water. I wonder if that’s not the cause?
RAYJAY
UNION DALE PA
I have well water ....... its the **** metal they use ...
