DirtAddsHP
- Joined
- Jul 28, 2011
- Messages
- 2
Hello,
I bought a used pressure washer with a Honda GC160 motor and a Karcher 2400 pump. It worked good for the first couple uses with the pressure kicking on nearly instantly when pressing the trigger, and then the response time start dropping and would loose pressure sometimes even with trigger still pressed after about 10 minutes of use.
Now i can only get the pressure to kick on for about 1-2 seconds and then the pump seems to kick back off. And for the most part i cannot get the pump to kick on at all, just a tiny bit of water coming out of the nozzle when the motor idling. the engine does not die, it just stops pumping high pressure water.
I looked at the air filter which looks okay and i checked the inlet nozzle which does not appear to be clogged.
Before i buy a new pump for $100 i would like to make sure that is the problem. I take it the carb is not clogged as the engine does not die, just the pump does not want to kick on in a timely fashion and keeps kicking on and off.
any tips or help would be much appreciated.
-Austin
-Austin
