Acuratechva
So i got two pressure washers each of which uses two different size water pressure outlet(at the pump). Shiiiiiit ton of sites to tell you every possible spec except for this. This dimension is not specified on ANY pressure hose or box store item info. Its the diameter of actual fitting inserted in to the pump, not the thread pitch ...
Comparing two units, Ryobi(gas engine). Uses smaller of the two
Stanley Electric and HF Electric. Uses larger. Both are standard 1/4 hose.
Wtf am i missing here, there is never any specs of this specific size they all only list the thread as if its the only important aspect. Pressure washers hoses on amazon/Hd all list "universal" clearly thats a load of horse dong. Im over googling if someone can chime in i'd be very grateful.
