rslaback
I know a bit more about pressure washers than the average chap but this one is a new one on me.
I picked up this Karcher washer cheap. I was told that it wouldn't build pressure. The gun had obviously froze with water in it and cracked the tube so I changed that out with a spare I have on hand. It would pulse and bog down. Eventually it got hard to even pull the rope. I took the pump completely apart and checked for stuck valves, ripped seals and plugged passages. The bearing was seized a bit so that was dealt with. I'm back to the pulsing action.
The unloader valve seemed fine but I wonder if a seal is leaking water around it or if the housing cracked in that area. I pinched off the soap tube in case that was allowing air into the system. I suppose it could be a dirty emulsion tube in the carburetor preventing it from spooling all the way up but I would expect starting issues and for it to die instead of pulse under load.
Before anyone suggests too low of water pressure, this big dog runs fine on the same hose.
