dougand3
Neighbor gave me a Troy Bilt Pressure Washer 020381 with Briggs 12S912-0121-B1 because it wouldn’t start. Tore it down - camshaft, oil slinger/gov, timing gear failures. Don’t know if I want to spend money on parts not knowing if pump works. Pump data is: Made in Italy MTPV93519 204763. So, had a Tecumseh LEV115 on an old, unused mower. All it needed was a flywheel key. Got it running good and mounted on PW cart with brackets. Same 7/8“ crank w/ 3/16“ key.
Problem: Can’t spin Tecumseh fast enough to get started. Hard pull at pump compression. Recoil was easy and smooth when on mower deck and blade attached.
Big difference: Briggs PW engine is heavy cast iron FW and Tecumseh mower engine has light AL FW.
Is FW difference my problem? Need to get more weight moving on FW side to get PTO crank past pump compression?
Should pump have a decompression assy that has failed?
Thanks so much for insight. Doug
