TT_Vert
I have a ryobi RY80940B 3,100 PSI pressure washer w/ a honda engine that seems to be acting strange lately. It always starts up perfectly but has a surge issue and also an issue w/ the RPM ramp up on occasion. I've looked at the exploded daigs to understand a bit more about how the governor works, etc but i'm confused what would be causing my issue. I have two issues actually. This pressure washer has an idle up feature that is supposed to bring up the RPMS when squeezing the trigger, is this monitored and controlled by a pressure change or water flow somehow?
This issues
1. As you can see in the video I get an rpm surge where I think the governor is moving (Hard to see in video). It repeats this continually. I thought maybe I had an air/fuel issue so I pulled the filter off but the problem persisted.
2. When i first start it many times i'll not ramp up rpms for sometimes a few minutes when squeezing the trigger. After it starts to ramp up as designed it's usually fine. Oddly many times if I squeeze it and let go it'll ramp up for a sec so I guess I need to better understand the design of this ramp up function to fix this.
Here is a video of what it is doing.
The unloader valve moves freely and looks brand new also.
Thanks much
Dave
This issues
Thanks much
Dave
