Pressure washer under $500
kunkernator
US of A
Well, my girlfriend just told me that she would buy me a pressure washer (that I've wanted for a while) for my birthday.
Under $500. Gas. And good quality. I've been looking at ones with Honda and Kohler motors, different brands, different specs. Horizontal, or vertical?
So, what say ya'll? Best brand, best specs, best value under $500.
nutsnbolts
Seattle, WA
I bought one last year for a cleanup and repainting of my back patio/fence area. I looked around plenty and ended up just going with this Craftsman. It worked great, cleaned the patio and the fence effortlessly. Unless you were going to use it professionally or had a really large area to clean regularly I couldn't see you needing anything more than this.
http://www.sears.com/craftsman-2800...p-07175492000P?prdNo=5&blockNo=5&blockType=G5
redmondjp
Redmond, WA
Curious why you aren't considering electric?
For occasional use, they are the way to go. I have a big-daddy pressure washer powered by an 18HP B&S Vanguard engine and I spend more time keeping that engine running (fuel lines, battery charge, fuel pump, etc) than I do using the unit.
Here is another option for the OP: Talk to your local rental places, as they sell their equipment when it gets a certain number of hours on it.
I passed up a great deal at my local Home Depot last fall (didn't need them) on two Mi-T-M electric pressure washers for $150 each - they were industrial-grade units with the triplex pump (that has an oil-filled crankcase) bolted onto the end of a 1 or 2HP electric motor. Came complete with hose, wand, and a selection of tips, all for $150.
For general homeowner use, something in the 1500-2000psi and 1.8-2.5gpm range is just fine.
On-Wheel
Bet you could find a very nice lightly used one for $500.
13 hp Honda ,4k psi-4 GPM for example.I never had luck with new $3-400 washers
B_Bimmer
Eastern Iowa
Australia
$500 will only get you a budget petrol pressure washer. However it will get you a very nice electric pressure washer.
Electric would be my vote. Unless you need it out on a farm or somewhere without power.
kctyphoon
Jersey/Staten Island
You can absolutely get a good enough homeowner gas powered unit for your budget.
http://www.pressurewashersdirect.com/quick_search.php
Change the engine oil and pump oil every season, don't let the machine run if your not using it, flush the air out of the lines before starting the engine, flush the water from the pump when you are done.. You do not need to spend tons of money..
If you plan on doing sidewalks and driveway, Definately invest in a cheap surface cleaner attachment, and water broom attachment. It will cut your cleaning time by 3/4..
If youre gonna buy one from HD or Costco, just go online and read reviews from people that actually own and use them.. This forum is the home of excess and overkill, so keep that in mind.
Tuscani2718
Upper Hudson Valley
I bought a predator 212cc from HF and a cat pump for I want to say $350-400ish. Works great, mounted it on an old crapsman frame. 500 all in and an hr of my time.
The DIY Hubby
Generac has a range of what they call residential gas powered pressure washers. Mostly in the $300-$500 range.
NewShockerGuy
Northern Virginia / DC
Got a Costco by you? I ask because I bought the electric start/manual pull Subaru one. I think it was $350 or 400.. can't really remember. I figured when it breaks, I just take it back and get my money back or get another one. Win win situation.
-Nigel
Lookin4'67Galaxieconv
Atlanta, GA
-Nigel
I didn't know CostCo was in the business of renting out pressure washers for free. Just curious, how's that a 'win' situation for Costco?
kctyphoon
It isn't, but when you offer a "no time limit on returns", you can't blame the people that buy from there for that insurance.. Bed bath and beyond does it, and so does lands end.
Anyway point being you don't need a $1000 pressure washer.. I probably have 200' of sidewalk I clean every year, along with my vinyl siding and fences.. I have a John Deere model, but only because it was bought for me as a gift. I personally stay away from anything Troy bilt from bad experiences with their engines, but I'd have no issue with a Costco model or generac / HD model. Just read reviews first.
jdcompman
South Dakota
I don't think anyone has said it yet, but look at Northern Tool. They have some nice units that use some quality parts and are assembled right over in Minnesota.
amalik
My electric ryobi does OK, it was under $200
You can get a "homeowner" model for <$500. The engine is not the issue. The pump, hose and nozzles are the issue.
Most non-professional pumps are not rebuildable. It you get a leak, replace the unit. The good news is, you can find replacement pumps for $100-$200.
If you are shopping in that price range, find a washer with a name brand pump (CAT, AR, etc) and check the model number to see if parts are available.
The problem with electric pumps is most do NOT have enough VOLUME flow (gph). You need at LEAST 2.0 gph to do any real work. To get that with an electric motor is going to require at least 2 hp, which means 240V, not common is most garages, nor are extension cords available at your local hardware.
I lucked out. Bought a used PW with no hose or gun for <$50. Cleaned out the gas tank and carb and bought a cheap hose and gun. Worked fine for a couple of year but developed an internal leak (milky oil). Replacement pump was about $150. I asked specifically if the pump was rebuild-able and was told, "Yes" (although there is no external oil drain/fill ... hmmm).
K
kunkernator
US of A
Alright guys, to clear a bunch up.... The reason i do not want electric is because of where I will be using it, i have used electric pressure washers and gas ones, and i just prefer the gas units.
As for the guys that think i have to spend over $1000 to get a good one, i have to disagree. I am not using it in an industrial or professional setting, just around the house.
I like the idea of finding one with a brand name pump on it, but I also want a good engine.
Kctyphoon, thanks for the link. I was browsing for a good hour last night, tons of good info too.
That is the one i am really leaning towards off of pressurewashersdirect.com, $400 and seems to have great specs, and great reviews. How do you like it? What tasks have been a challenge for it?
TLCObsession
Bellingham, WA
CAT pumps are great but the rebuild kits are crazy expensive. I would buy a GP or AR pump.
One other tip is winterize them - get some RV antifreeze and run it through.
bochnak
Mt. Prospect, IL
So far I have used it to clean my muddy motocross bike, concrete drive, & wood deck. Handles those tasks with no problem. The handle comes off and is pretty compact at that point, I can fit it in the trunk of my car no problem.
The only thing that I don't like about it is that the unit spins while in use from the vibration, so the hose gets wrapped around the unit. Also the rubber bumper foot rest leaves black marks on concrete due to the spinning. I know I can solve these issues however haven't gotten around to it. Maybe a softer bumper and some weight over one end would do the trick.
Overall I'm happy with it. My budget was 400 and this seemed like the best unit at that price point. I only use it a few times a year and did not want to spend more.
B&S, Kohler and Honda are all good engines. Subaru (Wisconsin) Robin I'm sure are fine, just not very popular. Same with Generac.
That Simpson one mentioned has a horizontal shaft pump which is a step up from the vertical shaft pumps (like mine :sad: ).
boiler7904
NW IN
K
kunkernator
US of A
Simpson ALH3225 with horizontal shaft Kohler engine and tri-plex pump is right at your $500 budget.
http://www.lowes.com/pd_516791-93684-ALH3225_1z0vj08__?productId=50119895&pl=1&Ntt=simpson+pressure+washer
I bought one late summer 2014 to wash my shed before repainting and use it to clean the siding, patio furniture, fence, driveway, sidewalks, underside of the cars, etc. Absolutely zero problems.
Was just going to mention that: $500 at Lowes. I thought the adjustable wand was a bit gimicky. Can you shed some more?
zak77
Monson, MA
I have the Homelite 2700psi with the honda engine on it and after 3 years it hasnt crapped out yet. I expect the engine will run for quite a while however i know the pump will die soon enough then i can get a cat pump for it. It was about $300 new and is sure MUCH better than the cheapo electric one i had. I'd like to have a better pressure washer but for the occasional use it sees, it's not worth buying a better one.
kctyphoon
I've never heard of anyone I know ever having to "rebuild" a pump for their pressure washer.. Number one rule, - DO NOT let the machine run without spraying water for more than a minute or two.. Anything more, shut it off, restart when you are ready..
Just some things I've picked up from using mine for so long. - don't waste money on some fancy expensive wand with a bunch a plastic and **** around it to make it look cool.. It's a waste of money, and anything unnecessary just adds weight, which ***** if you have to hold the wand upward for a long time. Buy a cheap, basic, bare boned wand. Take the handle apart and remove the trigger lock. Buy a basic medium length metal tub extension, that you can use with a clamp on type secondary handle, that you can clamp anywhere, at any angle, around the metal extension tube.. This is the lightest, toughest , 2 handle wand set up. Buy a 16" surface cleaning attachment from HD / lowes / Amazon..(about $60 or $70). I have the HD Briggs and Straton one.. It's ******* great - like the first time you ever used a nail gun great.. If you have a big area to work on, invest in a longer pressure hose.. You can get a 50' hose with the fittings off amazon for like $60 or so.. Most machines come with a 25' or 35'.. The 50' makes a big difference.. A water broom attachment is another great accessory. You can use the surface cleaner to lift all the dirt off sidewalks/driveways/patios, ad then switch to the broom to flush or "sweep" it away or into the street. Buy quick connect fittings for the garden hose.. It's SO much easier to put on, take off, and there's no struggling trying to unscrews hose ends that need to be tight to avoid leaking..
If you can find a machine you like for around $300 to $350, you can buy these cheap accessories to make the most of it, which will make your life much easier.. By all means buy a better machine for the $500 if you want to though, but the attachments make a HUGE difference in time and effort that will be spent using it. I would aim for something between 2800 - 3200 psi if possible, 2500 at a minimum, and maybe a machine that has an on-board soap/detergent container.. If you have to compromise - there is a clamp on gallon bottle holder that can be attached to the machine's frame to hold detergent bottles that must be fed via a siphon tube..
Good luck - post whatever you go with..
PS - I went though 2 Husky electric 1800psi units before getting a gas, my father went though 2 electrics himself before buying ANOTHER one off amazon..
Brace1
South FL
I agree. I bought one about 15 years ago (with a Honda engine and cheap pump), and granted I've only used it a dozen times or so it still cranks and functions perfectly.
K
kunkernator
US of A
Your advise has been most helpful. I just grabbed the 3200 PSI Simpson with the Kohler motor and triplex pump from Lowes, used a 10% off coupon to make it $450. I think it should work great.
http://www.lowes.com/ProductDisplay...romStore=true&partNumber=516791-93684-ALH3225
As for the wand, i like your ideas, but i am going to try to find one similar to what we have at work; it is a two hand design, and the second hand is a twist valve, the wand constantly flows water (thus not damaging the pump), and when you twist your hand, it restricts the valve to create pressure.
As for the spot sprayer, i am not fully clear on what it does? You stick it to the end of your wand and set it on a surface to clean the 15" circle?
On-Wheel
My $400 Simpson from SAMs didn't last long.The 3100 psi 2.5gpm,but I dought there all bad.I think the punp was really only 2500psi.Replacement pump wasn't worth it to me.Thats my review of it.
I see you bought one.Good luck and enjoy! Power washers are very nice to have.A great gift!
K
kunkernator
US of A
The one i chose is the cheapest one Simpson offers that has a triplex pump. From my understanding, axial pumps (cheaper) are not nearly as good, and dont last long. This pump is branded AAA, which I have yet to find anything negative about (at least it isnt unbranded).
I also find it interesting that every item on the unit is manufactured by someone else, it looks like Simpson just packages it all together. Not that this is a bad thing.....
Also, this thing is LIGHT, i am really digging the aluminum frame.
B_Bimmer
Eastern Iowa
I am really surprised aluminum frame's are not standard on better machines, they make them age very gracefully despite heavy use.
kctyphoon
Here - 2 birds with one stone - this guy has the same surface cleaner attachment that I do, and basically the same wand too...
Another benefit of the surface cleaner, is it won't leave any lines in the concrete like you might get just using a tip. Pressure and intensity varies a lot in just a few inches, so cleaning wood decks and concrete free handed can sometimes results in uneven cleaning.. This takes all the guesswork out of it, and will promise everything looks evenly cleaned. I've even used this with lower pressure (mine is adjustable) to do the shingles on my roof. The water pressure won't be as high as using a single tip since its two rotating tips, but it's not far off.. Meaning, if you just used a small angle single spray tip, it till get even more dirt out, but will take forever and can leave lines in the finished sidewalk.
On the unit I have, if you are not spraying water while the engine is running, the pump will eject some water to prevent it from overheating and seizing.. Regardless,,, I just shut it off when I have to move stuff around..
This is the 50' hose I ordered though Amazon.. Used it all last summer with no issues... It's not "the best" but very good and this way I won't cry if a $100 hose touches the muffler and springs a leak.. Its a great price, considering it comes with all the quick connects too...
Raptor Blast 4000 PSI BLACK Wire Braid Pressure Washer Hose 50' w/ Couplers https://www.amazon.com/dp/B0053GICUG/?tag=atomicindus08-20
And check out the frame mounted soap holder.. I have one like this on my John Deere that I put on.. One less thing to move around, and it keeps the bottle from spilling over by accident on my lawn. It's on the bottom of the page - http://valleyind.com/products/pressure-washer-accessories/fluid-accessories-and-chemical/
