Presure Regulator Parts??
Smoky14
Southern NM
I have a CH compressor which has a leaky regulator. It can be fixed by replacing the out flow valve. It consists of a rubber stopper about 1/4 round and 1/4 long tapered to go over a spring which helps close said stopper.
Search as I might I can't find a new stopper or outflow assy.
Anyone know where such small parts are available?
Thanks for your assistance
Smoky
larry_g
oregon
Have you searched on the term ' pneumatic regulator rebuild ' ? I did and it comes up with a lot of information. Without knowing the brand of your regulator it is a shot in the dark trying to figure out what you need as the terms your using are not industry terms. See if you can find a generic regulator picture that has the proper terms on it and then post back withthe diagram and the parts identified.
All that said I would suggest that if you have an unidentifiable regulator that you replace it.
lg
no neat sig line
