Princess Auto Deals.
lilredex
Toronto
A few..
http://www.princessauto.com/en/search?Dy=1&Nty=1&Ntt=8597239
3 X 21" sanding belts (Norton) in 36 or 50 grit ...five for $1.99 (In Surplus)
http://www.princessauto.com/en/search?Dy=1&Nty=1&Ntt=8578148
1 1/2 X 5 YD. waterproof Alum/oxide 120 Grit sandpaper (Taiwan) $2.99 (In surplus) #8578130 is the same but 10 Yds for $5.
http://www.princessauto.com/en/search?Dy=1&Nty=1&Ntt=8537805
8 X 1" medium Norton grinding wheels #3.99 (In surplus).
If you want to take a chance on router bits....twelve for $12,
on line purchase only.
http://www.princessauto.com/en/detail/jeu-de-forets-à-toupie-12-pièces/A-p8535528e
If you pick up any of those stones, be sure to give them the "ring test" before going out the door. They are new Norton stock, but you have no way of knowing how they have been handled.
I ordered a couple of the router bits sets as I have a few projects in mind for the winter months...D/T and box jointed boxes.
Abeo
Calgary, Ab
Bump this back up
This "14 inch dry cut metal saw" is on sale for $40
http://www.princessauto.com/en/detail/14-in-dry-cut-metal-saw-blade/A-p8141756e
But nowhere on the package does it say dry cut, and the max speed is 4500 rpm, not the 1700 rpm that the actual dry cut saw says
So, I asked about it, and got this actual dry cut saw blade for the sale price:
http://www.princessauto.com/en/detail/14-in-dry-cut-metal-saw-blade/A-p8539843e
They marked it down using the reason "the flyer had the wrong SKU listed"
$110 off! Your mileage may vary. The deal ends on the 31st
Chuckster in NJ
Hunterdon County NJ
mineallmine
Ontario, Canada
Maxline M7580 for $199.99 https://www.princessauto.com/en/det...ssed-air-piping-system-master-kit/A-p8700858e
It's packaged in a Princess Auto white box, just picked one up. Considering the Maxline 7500 (100 ft length) goes for $300 CDN, this is a great deal. Will update once I get home and open the package.
This is not a rapid air product. I purchased two back in September and when I opened the box the manifolds were not the same as pictured, fittings didn't have the same orings as rapid air and quality of manufacture was questionable at best. I contacted Rapid Air to find out this white box kit was not made by them but was a cheap knockoff by Princess Auto. I returned both unused as the quality was so poor. I bought 2 actual Rapid air kits and the quality difference is quite noticeable.
