Pro Tip: Use Antiquing Glaze.
DIY_Guy79
Tulsa, Ok
I got this Johnson 7" speed square.. or "Johnny Square" a while back. Opted for it over the Swanson for the scribing notches. And over other options for the cast graduations rather than the laser etched that will likely become unreadable and seem to be the new cool thing.
Anyways, I did not like that the graduations weren't painted. I kinda had to strain my eyes more than I'd like to see them in most lighting situations as you can see:
Anyways, I had considered using black paint. As I've done before on other measuring devices. As I was reaching up in the cabinet to grab it, I saw some Valspar Antiquing glaze. And I figured I'd give that a shot.
I was pleasantly surprised. The glaze was much easier to work with, much more forgiving, workable for much longer, and even gave me the ability to work the glaze over areas outside of the graduations to give a cool antique look. I had no intentions of making a relic square or turning it into a craft project by any means. It just happened and I'm very happy with the result. Had I used paint, I think the result would have been nothing near as impressive or as natural looking as the antiquing glaze. My only concern was that the glaze took an excessively long time to dry where it was puddled a little thicker. More than 16 hours later, I found it was still wet and decided to pull out a heat gun to cure it the rest of the way.
Anyways, the pics make it look a little newer than it looks in person. As the antiquing glaze has a brown tinge to it and I ended up just wiping it over the entire square which gave it cool vintage patina.
I highly recommend it if you have engraved/cast markings you're wanting to fill with paint or make easier to see.
Spacey_G
Wow, really nice tip. The square looks remarkably better—and much more functional—with the glaze.
alfazer
N. Ireland
Wow, looks great. Not tried this product personally, but when I paint metal parts like that I find it really helps to heat them first, then paint. The finish cures much better, from the inside out.
D
DIY_Guy79
Tulsa, Ok
Thanks for the tip. Hadnt considered heating the metal first.
That's a really good idea! I have the same square and am going to do this!
Nice. I found when I used my finger to spread the glaze it gave a much nicer effect than a rag or foam brush. As the rag & foam brush tried to take too much glaze off where as my finger left it and smeared/smudged it. The powder coat finish thats on the square has a somewhat rough texture, so your finger will let the glaze lay in the low spots of the texture. I didnt use gloves, but you may want to use some nitrile or latex gloves for potential safety concerns and less mess.
Griff79
Denver
Do you guys think this would work on chrome sockets? I have older sets of Craftsman that work well, I am having difficulty reading the numbers with these old eyes?
Griff
D
DIY_Guy79
Tulsa, Ok
Griff
If the numbers are engraved, it might work alright. Might have a little harder time adhering to the chrome. Just make sure they're completely clean of any grease, oil, or dirt. And give them plenty of time to dry. Might try heating them like suggested above. Although paint might be a better option, as I think paint is a tougher material when dry than the antiquing glaze and may hold onto that chrome a little better. Hard to say, doesnt hurt to try either one.
The paint and the antiquing glaze are both nice to have on hand so its not gonna be a bad investment for either one. I think the antiquing glaze was around $12 or $13 for the 16oz container.
If you want to try paint, I usually have Rust-Oleum Oil Based Stops Rust Protective Enamel on hand in a few different colors... Great paint for stuff like this. The pic is a quart, but you can get 1/2 pints at Walmart or wherever. Think they're around $6 or $7 each:
