Was doing a timing belt on a 94 Accord today and managed to snap off one of the bolts that holds down the water pump. Got about 2-3mm of the old bolt sticking out past the block which isn't much to work with on account of the bolt only having a 10mm head to start out with. I have about 4-5" between the block and the wheel well, definitely no room for my big *** drill. Current hope is to find small enough locking pliers to grip it and turn it in that tiny space... Tried to cut a slit in it with a 2" angle grinder but I couldn't hold it still enough. Just shaved a little precious material off instead. Any wisdom out there for a tight spot like mine?
Jorwood
Jorwood
