proactive heat pump replacement?
vavet
Ashland, VA
The situation is we own a second house that was our home for 9 years. We moved out about 8 years ago and we've had the same tenants in there since then. They've notified us they do not intend to renew the lease when it expires in June.
The heat pump was replaced in early 2010 - 13 years ago. It was a mid-grade unit when installed. I think it's a Bryant 2.5 ton unit in a 1620 sq ft cape cod style house in central Virginia.
It's been fine.
I'll plan to have it checked after the tenants move out to get an evaluation of it. If it's clearly used up, then we replace it. If it gets a clean bill of health then it stays. The extremes are easy. It's the middle ground that I don't know about.
My understanding is that we should expect it to last 12-15 years. Do we replace it proactively and not have to worry about it again? Or do we let it go and possibly inconvenience our future tenants and maybe have to move them into a hotel for a few days if it fails during extreme weather?
Should I get it checked now during colder weather and then again when it gets warm to get a full picture of its state of health?
How reliably can a service tech predict the future service life when looking at a heat pump? Is it just a shot in the dark based on age? If the refrigerant pressures are good, the motor running currents are within spec, and the output air temps are OK, then there's nothing to fix. What else can they look at to evaluate it?
jlv03
SE IA
I assume there is a backup heat source on it (heat strips or dual fuel gas furnace)? If so, I don't think you'll need to spring for a hotel when it is extremely cold.
Extreme heat - may need to pick up a few window units to get by.
dcg9381
Austin, TX
I'd clean the coils, maybe replace the caps... Check to see if it appears to be in good running condition... Probably wouldn't replace, IMHO.
larry4406
Northern Virginia
I think I would do a thorough PM and then fix when fail.
With all of the supply chain disruptions and loss of talent in the field, who's to say that a new installation will be without fault?
