probably a stupid switch location question
skipdup
Spring Branch, TX
Can I put a switch on the opposite side of the same stud a panel is hung? Or should I move it over in the cavity to the next stud?
And do water lines in the same stud cavity matter?
Thanks,
Skip
bigb56
Tucson, Arizona
If you want to put the switch there add a scrap 2 X 4 first to space it away from the panel a little for wall plate clearance, and so you won't have to put such a tiny strip of drywall there.
skipdup
Spring Branch, TX
Kind of an obvious answer, now that you point it out. :)
Thanks!!
