Probably too big for the post your toolbox thread, 56k be warned.
Stick
Alaska
One of the three toy story aliens that live in my toolbox, placed there by my kids.
The air tool drawer, everything from die grinders, impacts 3/8" to 3/4", an air powered vaccuum, a solvent sprayer, a 2" grinder, and more.
A snap-on pneumatic scraper, great for gaskets on heavy diesel engines that have been glued in place with cat green glue.
Metric wrenches through 19mm or so.
Standard wrenches through 1" or so.
Assorted specialty service tools.
Drill bits through 1", transfer punches, pretty much just fabrication tools, drawer 1 of 3.
The drawer of big tools. Standard wrenches though 2", Metric though 36mm. Sockets through 2 1/2", 3/4 drive ratchets.
The preferred method of keeping big wrenches in place, a large spring.
Prybars, punches and chisels, bearing race drivers, wilton unbreakable sledgehammers (4# hand size, 8# 2ft and 12# 3ft), break-in tools (big easy is in the top drawer, the accessories are in here) and lockpicks. Specialty diagnostic tools (noid lights, vaccuum test kit, oil pressure test kit, hydraulic test kit, gas and diesel compression gauges, etc.) An airlift for coolant re-fills.
Everyday use pliers.
The rest of the pliers.
A couple of different kinds of vice grips, fabrication tools drawer 2 of 3.
Enough orange hard handles to make most of you jealous. ;)
Electrical tools, Anti-zaps for welding on equipment, zip-tie pullers, assorted terminal tools.
A couple of pullers, the shop supplies the rest of them, per union contract. Also a rarely used ratcheting screwdriver kit.
Fabrication tools drawer 3 of 3, also 4wd spindle nut sockets in the plastic box.
Hydraulic caps/plugs through -24 in JIC and ORFS, commonly used rivets and riv-nuts, assorted misc.
Lube tools, with the exception of my biggest filter wrench which won't fit in that drawer.
Hammers, I hate the new style red handles with the exception of the deadblow hammers. I much prefer the orange handle hammers because the heads are narrower. Both of the large ballpeen hammers are 40oz, and you can see the difference.
Welding hood, respirator, battery load tester (in the black box), caliper compression tools, under the tray is a oiled hub drain pan for big truck hubs, misc. other stuff.
That's (mostly) it for my personal tools, some of the cooler shop stuff follows:
Drill bits through 2"
Platen style welding table.
Lathe, the tan cabinet contains tooling for it.
Wilton drill press, sheet metal brake.
Plasma, big drill press, Miller welder.
And since I knew someone might ask, it's a shopmaster 300, with an XR wirefeed with a 30' push/pull gun and .045 wire. Also runs a HF/pulse box for TIG. We also have a Lincoln Idealarc 400 if you really want to get down and dirty with stick welding.
New toys at work. Lift system for big trucks, they lift 16k each, wireless control syncs them together. They'll pick up 64k combined to the same height as a standard automotive lift.
And Last, a couple of pics of what we work on.
A new M-series Cat roadgrader, no more steering wheel or levers, it's all joystick controls on this one.
It's in the shop for a busted snow gate. We do a lot of medium to heavy fabrication work. The gate is one of the things we built. Grader plows snow with the gate up, when a driveway comes up the gate goes down so we don't leave a berm in front of the driveway.
A snowblower. It'll fill a 13yd dumptruck with snow in about 30 seconds, depending on how wet the snow is. It's carried/pushed by the 966 loader behind it.
mkdive
NPB (Socal)
Very, very, VERY nice box & tools! Thanks for the post I enjoyed looking at all the pictures!
eschoendorff
Wow... nice! I like how you use a spring to organize the wrenches - clever. :thumbup:
That snow gate is a really neat, thoughtful piece of equipment. I wish that they used them over here.
GDA
Dallas, Texas
Very cool and great set of tools. I can only imagine the types of cool stuff you get to work on/fab up in that shop.
S
Stick
Alaska
It's the city shop, so we work on all of the city owned equipment and vehicles. Everything from police cars and fire trucks/ambulances to garbage and dump trucks, paving machines, loaders, graders, etc. If it's owned by the city, we fix it. I would have taken pictures of the firetrucks and police cars, but we didn't have any fire equipment in the shop, and the only cop car was an unmarked undercover unit.
The best thing about the job is the amount of fabrication we do. I've done everything from specialty truck racks, to accessories for the paving machines, to snow gates, to k-9 conversions for police cars. If they can think of it, and the money is in the budget, we'll build it.
Merkava_4: The mac wrenches are great, but I do wish that I bought the extra long versions, instead of the standard length ones that are a bit on the short side.
justinmc
KCMO
Stick... ok take your big Macsimizer box and your collection of fancy orange hard handled S/O screwdrivers and go play somewhere else. I am JEALOUS! haha.. loving that setup man! I keep telling myself I should buck up and find a good Mac box like that but thus far.. my wallet still says no!!!!!!
Oh and I'm with everyone else.. the spring storage for the wrenches is perfect. Do you just use the wrenches weight/etc to keep it spread or is it affixed in the drawer somehow? What did that spring come off of? Oh no.. I'm not stealing your idea ;)
S
Stick
Alaska
The spring is about 1.25" in diameter, and the weight of the wrenches is enough to hold them in place. I can't remember what the spring came off of, but I did heat it up with a torch and spread it out enough for the wrenches to fit into easily.
Feel free to steal the idea, it's one an old-timer showed me when I first started turning wrenches. He also showed me the way I prefer to store crowfoot wrenches. If you look at the wrench drawers, it's a 24" mag rail (cut or buy to fit your drawer depth) along the left side of the drawer, it makes it easy to see what size you are looking for. Usually it's unused space anyway, and as long as you pick the crowfeet straight up off the rail and don't slide them off, they won't become magnetic.
tatra
pirate contest city
been using the spring idea since i first saw it in 84 as an apprentice where i work...........i use it diff. sizes for just about everything, wrenches, drivers, pliers etc.....you do need to take the time to fit them to your application as trial and error is the only way to get a good fit..........added bonus is the ammount of room you get instead of dispalying them at an angle.........course height does become an issue in shallow drawers...............and the anti berm/ windrow thing should be law on all grafers doing snow.............:beer:
