So long story short I've got a problematic floor in my garage. I moved into this house about a year ago and have been working on the garage ever since - now I'm at the point that I can start working on the floor.
Problem is it looks to be 3 or 4 different slabs, and as near as I can tell, it's only about 2" thick in most places and sitting right on the dirt - no compacted gravel, no vapor barrier etc. To make things worse, there are no footings whatsoever and the walls of the garage are resting directly on the edges of the slab (which have settled and cracked).
I know it sounds really bad, but I've been able to stabilize the structure and get it looking pretty good inside if I do say so. That said, I realize the floor will never look like some of the smooth epoxy covered floors I see on here, and I am certainly realistic about my expectations. Basically, I'd like it to all be one color and not have any large holes in it!
Anyway, here are a couple photos of the current condition and the problem areas:
Old post hole:
I know the best option would be to just re-pour the slab but that's not an option for several reasons.
So my plan is to rent a pressure washer and blast off all the old paint, patch it up as best I can with concrete patcher, then just paint it with a half decent concrete paint. I know the paint won't be nearly as durable as epoxy, but I'm okay with touching it up every year or 2. Anyhow, does that sound like a workable plan? would I still have to etch such an old slab with acid or would pressure washing be enough?
Thanks, oh and a couple shots of the outside for my inspiration!
Old post hole:
