HandyNotHandsome
- Joined
- Sep 1, 2024
- Messages
- 2
I have a Chinese parking heater that I've been fueling with old heating oil, run through a couple filters and a separator. Recently it stopped pumping (no clicks). I took out the pump and rinsed with some WD40, and saw that it pumped just fine when I applied 12V. So I put it back in, and now the pump seems to work, but it's not actually moving any fluid - there seems to be some obstruction past the pump. If I disconnect the pump outlet, it sprays oil just fine, but if I re-attach the outlet, it clicks but does not move fluid.
Can anyone suggest a likely cause or location of the obstruction, and/or fix, before I dive in and take this thing apart?
