Hello all, I recently purchased a maxjax lift, I have radiant in floor heat in my slab. Had a friend of mine come down today with his flir camera to locate the pex piping so I could drill the holes in the slab. The first post is ok all 5 holes miss the piping but the second post I could only get the four outer holes clear, the back middle on is on a pipe.
No matter how we moved the post around there was always one hole over a pipe, the heaviest vehicle I will lift is my quad cab silverado which weighs about 5200 lbs then I have a couple of tdi jettas and a 69 firebird which all come in around the 3200 lbs range. So I'm thinking one post will have all 5 bolts and the other will have only 4 bolts in it.
Has anybody ever had the problem where they could not get all the anchors in? If so what did you do? Looking for a little advise here.
Thanks
Thanks
