Problem with table saw switch
Scottishross
I have just brought a table saw
There's a problem with the switch turning it off and on
I took the yellow cover off and found this
The spindle bit is fine but the plastic cover keeping it in place is broken
I'm thinking of replacing the switch
The question is will any 110v switch do :dunno: for the table saw
I was thinking of something like this
Or does it need to be the same manufacture
Scottishross
So basically any switch will do as long as I make sure the volts and Amps match
Charles (in GA)
50 mi south of Atlanta
Match, or are greater. the exact switch you illustrate, from looking at the decal visible on it, is a 35amp, 125V switch. It would work well and be a great switch for this. You might have to mount some sort of new box to mount the new switch on, however.
Charles
LS6 Tommy
Northern NJ
Start/Stop switches don't always replace regular On/Off switches. Many S/S are momentary, not maintained like an On/Off. Make sure you check.
Tommy
yeldogt
New stationary table saws come with a magnetic switch... they look like the third picture -- if the power goes off they will not restart without pushing "On" again.
But any switch with the capacity to match the motor will work
Norcal
http://i346.photobucket.com/albums/p413/rossmcleod/de21ab6823ce54ec7bc7d5e209479800_zps32b0255c.jpg[IMG]
[IMG]http://i346.photobucket.com/albums/p413/rossmcleod/e796b1d7160c7033bdec6d6b7f2e2c8a_zpsd5b1eb71.jpg[IMG]
[IMG]http://i346.photobucket.com/albums/p413/rossmcleod/d660a3fd0ff9f6100bb5eb4a93f42b33_zpsab8e0fe9.jpg
The switch pictured is UL recognized, not listed,(it's not the same) & is just cheap Asian junk, a decent magnetic starter or manual one as long as they are a NEMA style is a good reliable choice.
lbmcse
If the poster recognizes the difference between momentary and maintained, he'll be fine as long as the ratings match. As far as Asian junk; one would be pretty hard pressed to avoid these components nowadays--even in Made In USA items.
Scottishross
i cant find a switch that will do the job
I can fine switchies the will do 240v not 110
LB-1911
Northwestern Il.
Charles (in GA)
Something as simple as this, but even this is $60 from Fruitridge tools who are as reasonable as it gets.
VVV Similar but with a pilot light and cheaper. VVV
$43.75 including shipping on a BIN from an Ebay seller.
Same thing but cheaper
This the same, slight variation in part number, I think it is a lower amp or hp rating but $20 plus $8.75 shipping and will take offers. $15 plus shipping will probably get it.
Square D brochure with all the specs on the toggle/snap switch style motor starter units
Charles
Charles (in GA)
It isn't all about amps however. Make sure whatever you use is motor rated for the appropriate HP you have. Motors have high inrush current and many switches cannot handle this even though they can handle the running amps of the motor.
Charles
sands35
St. Joseph, MI
The nice thing about the green/red push button is you can hit it with your leg/knee. There is also a pin you can put through the green button to lock out the tool.
A toggle switch on a power tool isn't the best from a safety perspective. There is a reason emergency switches are all push to open.
sublimate
Colorado
^This^
In fact, I'd recommend something like this switch to make it easier to shut off in an emergency:
http://www.rockler.com/safety-power-tool-switch
LS6 Tommy
Northern NJ
I wouldn't bother paying for the switch with the pilot light unless you can't tell the table saw is running...:lol_hitti
Tommy
Cameronl
Connecticut
Tommy
I once bent down to pick something up while wearing earmuffs, placing my hand on the saw table. I thought the saw was off. When I stood up I saw that my had was inches from a spinning blade. :shocking:
G_P
Central CT
My table saw just has a light switch mounted in box on the side. :dunno:
Only a 1hp motor and it has been working fine for 15+ years.
