theshallowbay
- Joined
- Aug 24, 2015
- Messages
- 5
I just bought a ProFusion 5000 W 240-Volt heater for my garage. My garage is finished and attached to the house. I want to wire it tomorrow and have some questions. I've literally only replaced a few switches and outlets in my day so go easy on me.
1. The most direct route from panel to garage is a wall cavity that has duct work in it. Any problems routing the wire this way?
2. I need to drill some wall studs to run size 10 & 12 Romex. I read that a 3/4" hole centered in the stud is the way to go. Can I run both wires through the same hole or should I keep them separated? If separated, how far apart should the holes be? Anything wrong with drilling towards the bottom of the stud?
3. I would like to wire in a thermostat. The manual states it must be rated for 26.5 amps or higher. All the stats I have found have been rated for 22 amps or lower. Considering the heater only pulls 20.8 amps, would I be fine using a lower amp model?
4. There's a switch right below the potential heater spot that controls an outdoor light. I would like to put a switch for the heater right next to it. Can you run two separate circuits in the same switch box?
Any help would be appreciated. Thanks!
