rieferman
The finished 15' x 15' area in my barn will be insulated and I was planning to use baseboard electric (hydronic) heat in the winter time, one of the stand alone plug in models or maybe hard wired depending on options. For the size of the room, the amount of time we occupy the room, and the cost of the heaters, this seems to be the most reasonable way to go.
The room will be used as an exercise room - I generally do my workouts at 6 a.m. before I get ready for work...
So that the room is heated in the winter by the time I get out there each morning, what are the options to make this type of unit programmable (do I need a wall mounted programable thermostat similar to what I have in the house.. the honeywell touch screen type of setup)? Must the heater be hard wired to take advantage of a programmable solution?
