Project help, air compressor related.
Treecat
Not sure exactly where i should be putting this
Im looking to build a box that will allow an air compressor maintain a constant low pressure in a rubber bladder(deal with leaks etc)
I know how to plumb it up(I've used a commercial version on a larger project) just not sure exactly the terms I should be searching for the valves.
Any help is much welcomed.
stonesfan68
Houston, TX
Are you looking for a pressure control valve? It is also sometimes called a pressure regulator.
engineer2
Chicago burbs
A two-stage regulator might be something to look at. Many come with a CGA inlet fitting, but there are many industrial types out there with regular NPT fittings.
