Ryan
Administrator
Boulder/Koloa
So I've been tackling a lot of maintenance projects out in the shop lately. For the most part, they are all projects that take a weekend or more to finish and I've caught my...
slim53
Bloomington, MN
The tool cart for sure. I still need to get a couple for myself. Maybe more. The reality is you generally use the same basic tools over and over. Why not keep them together and mobile? I prefer a cart with a drawer since its easier to keep the dust off the tools (I do body work from time to time). Also, you can divide them up better. Maybe keep you basic hand tools/sockets on the top, but in the drawer keep (if you got a flathead) a 2nd or third tune-up kit.
It's nice in the shop, but what happens when your buddy's hot rod starts fussin on the way over to your house? Do you back your cars out and pull his in or do you just roll the cart down the driveway? The latter seems obvious, but I can't count the number of times my friends and I have laid tools all over a driveway.
Slim
35mastr
Norcal
Ryan,The cart is the way to go. I use the ones on the right. Then when all work is done. All tools get wiped down and back in the big box.
Plus I use cart to move heavy stuff also.
They can be real handy when needed.
In our shop we have what we call a "tool tree" Basically a bunch of fence posts welded together on some casters with nails all over the place to hang wrenches, sockets, and other tools on. Will have to get a pic. I really like it.
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
I've seen carts like the one on the left at Wally world before, then I see them elsewhere for more money. For more money, I wish the bases were heavier, so they could be used as a wheel mover.
Laredo
Stillwater, MN
Have used a tool cart for years - both professionally and at home for hobby stuff.
1) prevents tools from being left in bad places (under the hood, etc)
2) provides easy and convenient place for removed parts, bolts, etc
3) makes for easier cleanup and organization after the job is done
Fedwrench
Valley of the sun
It probably depends on available space. If your main box is two steps or so from what your're working, than you may not need a cart. I use a combination of both styles at work. I have a tool cart with drawers that has common hand and air tools in it to handle 90% of what I do. Depending on the job being performed, I also use an open two or three shelf cart. This is cart is like a rolling bench. All pieces removed from the vehicle are placed on the cart. It keeps things organized, safe, and out of the way. I would also recommend the addition of a folding side shelf on your tool cart. This gives you an area to lay a wrench or socket where you can easily and quick grab it again and again. As others have pointed out, things often disappear when you lay them under the hood while working. The use of a tool cart or tray can greatly reduce these losses.:beer:
foshap
I happened to see this blog. We happen to be the inventors (3 of us) of the Universal Air Tool Organizer. But if you look at the other products we've invented and patented, I think you will be impressed. Sears is currently selling them under the Craftsman Brand. Our 16 gage powder coated Pegboard Adapter allows you to organize retractables along with air tools and electric drills. Great for workshop projects. Offers quick retreival of most used tools. I'll roll my roll-away to my car. My 50' retractable air reel pulls backwards meaning I use the retractable portion and pull back to air source and connect with a simple adapter I made. The other end, I put a curly hose on it and perform work. When job is done, simple unplug and spool back to roll-away. Very simple and organized. The die-cast aluminum Air Tool Organizer is great for holding paint guns and very strong. To see a demonstration, go to www.airtoolorganizer.com or www.gmflabs.com
Thank you,
[email protected]
trainer
Northern Ontario, Canada
I ended up with a dozen bottom trays from gas bbqs that we replaced at work under warranty. they are about 12 inches by 24 inches by 2 inches deep. I welded a handle on each one with a slot for small hardware and parts.
If im working on something that has to be apart for a while, I put all the pieces into a tray and slide it into a spot under my workbench.
Right now, I'm in the middle of a bathroom reno. One tray has plumbing fittings, pipe cutter, solder, teflon tape, pvc cement, sparker for the torch, etc. one has electrical, and one has general nails, screws drillbits, sawblades, and screwdrivers.
Old Donn
Got one of each. A tray with the AC Delco name on it, and a Craftsman 2 drawer tool cart. Both are put into use any time I've got a project not in the basement right next to my tool chests.
TejasBimmer
off I-35, TEXAS!
I have my mobile chest from LISTA. Big enough and fairly easy to move around. It carries my tools used for my cars and truck, which is all metric.
Then my stationary tool chest is for SAE stuff and everything else for the home (wood work, cordless tools, etc.).
Its the one on the left.
I like that CM tool cart....I think I will get it.
For Christmas, my wife bought me that rolling seat from Groits...it has a tool tray underneath.
It works great and rolls with my big **** on it. ;)
ovilla
Plainfield, IL
Nathan - Do you have a pic of just your garage floor? That's a cool pattern you have going on there. Thanks
70redbee
Knoxville,Md
I have several 2 and 3 tray tool carts around my shop. I buy them from HF when on sale for about $40. I put tools in one and parts in another. You can't beat them for the price and it keeps things right at hand. When done with a project just roll it to the big tool chest clean your tools put them in there place and everything is nice and tidy. Works great for me.
nightrain00
I have a cart like that I forget how it arrived at my garage but I mounted and aluminum baking tray to the top of it so it has a lip to keep stuff from sliding off and is easy to clean. I just drilled acouple of holes and used carrage bolts to hold it the top that was already on it.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I like that piece. Anyone have actual experience with it? Wheels easy to roll/large enough to get over irregularities in the rolling surface? HD enough to carry multiple parts/tools? I see in has a shipping wt of 25 lbs.
I am using this now. It works pretty good.
Pretty much can guess where that came from :) If I'm not mistaken it looks like a Hospital cart. Correct?
SportFury59
Wisconsin - Wausau Area
Speaking of baking trays, I saw one time where a fellow bolted a baking tray to a spare old radiator cap and attach it to radiator and would use it as tool holder on an old car he had. Probably wouldn't work on newer cars.
1991Syclone
Englewood, FL
I vaguely remember something similar to the tray except that it was big enough for someone to lay on while working at the back of a packed engine bay. Sometimes you need to get to the back of a SBC dissy and it's a pain to have to climb up on the front bumper to get to it. I'll try to find some pics.
RetroJim55
Abbottstown , Pa.
I have two big tool boxes that I keep most everything that I don't use all the time . I have a cart with 9 drawer tool box on the cart with sockets , wrenches ,screwdrivers and the hand tools I use all the time . I just use that but the tools that aren't cleaned yet are just left out on the cart next to the tool box until the job is done . I keep the cart next to the car for easy access ! Been doing that many , many years !
