propane and mapp gas
subarub4
Connecticut
I have a question I have a bernzomatic kit a propane with the brass torch do I need to get another torch for the mapp gas?
MrMark
Southern Cal.
I don't think so, but after reviewing the heating specs there isn't much temp difference with the bernzomatic turbo torch heads.
rhandwor
My map gas head is totally different than my propane torches head. I purchased mine at a flea market.
S
subarub4
Connecticut
I just need it to heat up some steel to bend... I was able to do it with my propane but it's slow.. took at least maybe almost 5 min and still it was a dull red.
MrMark
Southern Cal.
mapp is only 250 degrees hotter according to the Benzomatic chart. It's not as much different as you might think.
edit: only 150 hotter! Why bother I am now wondering. Why do I have mapp?
PT Doc
My Ace hardware torch that came with a propane bottle cannot be used with map gas per the manufacturer. I called and specifically asked since I was going to be soldering copper to brass fittings.
djjsr
In the cornfields
I have several torches and grabbed one to use on a mapp gas bottle. Within a minute, the tip of the torch was glowing red. Not good. Don't use a torch that's made for propane on mapp gas.
MrMark
Southern Cal.
Side question: what's the best way to tell how full the gas tank is? I remember something about condensation?
MrMark
Southern Cal.
How long do you need to do this?
The flame temp of oxy propane is 4600
Propane in air 3450
Mapp in air 3600
Home Depot sells a brazing kit - either oxy propane or oxy mapp, I forget that uses two small bottles. I seem to remember the kit being around 50 bucks. I could be way off though. Sounds like you could use that kit.
S
subarub4
Connecticut
Propane in air 3450
Mapp in air 3600
I saw that kit the bernzomatic one right? I was reading the reviews and most said they had a problem getting the mixture right.
And this is just a short project so i don't need like a 10 Lb tank or anything crazy like that.
Frank The Plumber
Chicago.
Nice little chart there on the Bernzomatic site, color coded, real pretty. Might get to keep your eyebrows. Some were, some were not. Seems there is a new fuel mix being intro'd as well. I was gonna just say yes but had a look. Glad I did so as not to give bad info. Thanks guys.
Frank The Plumber
Chicago.
What are you trying to do?
There is a venturi inside the torch tip, it is supposed to be deep in against a seat stop, that's how they come new, if it's forward or bent it causes the tip to over heat.
These disposable bottle units are good for soldering 1" copper at best reliably.
I'm not disputing but I have a hard time believing 3600 out of one, more like 2700 I thought. And not over a very large area.
S
subarub4
Connecticut
I need to bend a 3/8" steel rod. Not home right now but this is all I was able to do with propane.
diggerrick
Are you looking for more temperature or more heat?
I'm sure propane will get it hot enough to bend, but a bigger torch will get it hot faster and spread the heat into a bigger area.
I think that's what the rosebud tip on my oxyacetylene torch does.
S
subarub4
Connecticut
I think I would be looking for more heat the propane is OK... BUT the flame size is small.. however I would need to get a propane tank right? Since I don't have one I think I would be looking at what $50-60 for a new tank?
diggerrick
My tank was $30 from Menards.
It's nice to have a spare for the grill too.
I've been having fun with mine burning weeds.
BTW - there is also a non-pushbutton igniter available for $5-10 less.
S
subarub4
Connecticut
Never heard of Menards before.. A tank exchange is cheap.. but when you never had a tank before it's not so cheap.. I thought about buying a new empty tank but thats not very cost effective as well so I have to **** it up and spend the $60 or so for a new tank.. 20 Lb should last awhile I hope.
nate379
Palmer, AK
Frank I have soldered 1.5" copper fittings with just a small propane torch. I almost put the welding tip on my oxy/acy torch, but figured I'd try the little propane one first.
Op... maybe best option would be to find local fab/welding shop and have whatever you are doing bent up. The couple $$s or case of beer will be cheaper I'd bet they buying a setup.
I have bent rod about that size with Mapp, but it barely got it warm enough.
2oolhound
BC Canada
+1 on that one. It looks like you're not getting clean bends now, just take it in and get it done right. You could also try a blacksmith club.
S
subarub4
Connecticut
it does not have to be spot on.. that more or less was just me messing around to see if I could get it to bend.. I first did the 90 degree bend with a pipe wrench with no heat.
S
subarub4
Connecticut
just in case I mess up I ordered some bent j hooks from summit anyways they kinda fit but it needs to be bent out about 3-5 degrees so it sits flush
I guess a nice hammer when it's hot should get it close enough? I'm running low on propane in my little 14 oz tank.. but I've had this tank for 4 years (shows how much I use it) So I've had it for awhile.
Here's a picture.
S
subarub4
Connecticut
Well here is what I did I picked up some ready made J hooks from Summit and just heated up the end where I needed it to lay flatter which worked..
Ah but gotta love welding putting the hooks on and only a few seconds needed and the hook is glowing :shocking:
