vavet
I have this weed burner from Harbor Freight.
www.harborfreight.com
The hose fitting included Is for a 20lb propane tank. I’d like to refit it so I can use a 1lb propane tank to make it easier to carry around. The fitting appears to be a 3/8 NPT male so I’d need to convert that to the 1lb propane cylinder fitting, which I think is 3/4 NPT.
If I remove the male fitting, I find it is a 1/8 NPT, or at least I think it is. I used a 11/16 flare nut wrench for this, but a 17 mm is actually a really good fit, probably better than the 11/16. Is there a metric equivalent of NPT?
next Question….is there a problem with using a propane cylinder turned upside down? Do I need to fab up a crooked pipe so the propane cylinder is upright?
Propane Torch with Push Button Igniter
Amazing deals on this Propane Torch W/ Push Button Igniter at Harbor Freight. Quality tools & low prices.
